Old Jun 20, 2024 | 08:23 PM
  #9631
Discorama's Avatar
I got an air grease gun. It makes greasing the drive shafts so much easier. The grease is pushed through in pulses with high pressure which results in faster and better greasing. With the hand grease gun I had to pump forever until grease came out at all four needle bearings.
Old Jun 21, 2024 | 10:49 AM
  #9632
YETIX's Avatar
How boujie!
Old Jun 21, 2024 | 07:50 PM
  #9633
Discorama's Avatar
I installed the beefy track rod and drag link from Terrafirma and an OME steering damper. Checked the steering alignment. The steering wheel needed some centering but the toe didn't need any adjustment.
Old Jun 23, 2024 | 09:02 AM
  #9634
mollusc's Avatar
Can you explain how that is checking the toe-in please?
Old Jun 23, 2024 | 03:04 PM
  #9635
Discorama's Avatar
@mollusc The idea is to measure the distance between two bars attached to the front wheels. I used the caliper to make sure that the bars are correctly aligned with the rims and not something else. The pictures don't show the complete setup and measurement of distance of the two bars at the ends. I should have taken more pictures of that to make that clear.
Old Jun 24, 2024 | 08:17 AM
  #9636
mollusc's Avatar
Okay, that's the method that I use except for the depth check that you did.
Old Jun 24, 2024 | 07:26 PM
  #9637
mln01's Avatar
Originally Posted by Extinct
Sounds like your factory design stat is beginning to suffer from the bypass bleed through. ...
Extinct, would you please explain bypass bleed through?
Old Jun 25, 2024 | 08:36 PM
  #9638
Extinct's Avatar
Here you go:
Old Jun 26, 2024 | 01:08 PM
  #9639
Harvlr's Avatar
Thanks for that Extinct. I never really understood all that before.
Old Jun 26, 2024 | 04:57 PM
  #9640
Extinct's Avatar
You would have thought they would have learned their lesson the first time but they didn't and they put the same style thermostat on the new 5 l engine
