whistling airtake?
Old Mar 8, 2007 | 04:37 PM
lowill's Avatar
Default whistling airtake?
Sounds crazy but my air take makes a crazy whistling(almost like a bearing ) sound from time to time. Its a 98 disco le 98,780 miles. Iused seafoam in the airtake weeks ago and it made the same sound as I poured it in. Brought to my buddy muffler shop and he said that it soundslike its coming from there. Only does it at idle. Stops when I give it gas. What you guys think of this one. Yeah this rig makes the regular sounds but this one is annoying.
Old Mar 8, 2007 | 04:42 PM
98roverguy's Avatar
Default RE: whistling airtake?
I'd check to make sure you dont have any leaks and such throughout your intake system. Tighten all your clamps and such. Also, do you have the liitle what appears to be a horn still attched at the beginning of your air intake system? Those are designed to quiet the system. Is the air filter restricted at all?
Old Mar 8, 2007 | 07:21 PM
98roverguy's Avatar
Maybe some rovers just like to whistle while they work.[sm=icon_rofl.gif]
Old Mar 9, 2007 | 01:03 PM
lowill's Avatar
weired thing is that when I bought the truck the under hood lineing was messed up by the air filter box. when I changed the filter it was covered in that material. the whole inside of the box was messy. my guess is that it suck some debri inside(hope not). by the way can i take that liner down with out it messing up my hood(burn spots).all clamps are tight dont see that horn thing.
Old Mar 9, 2007 | 01:37 PM
Aquaholic's Avatar
Check the butterfly valve actuated by the throttle. It's only closed at idle - and if the area is dirty (carbon build up or your hood lining) it may whistle when closed.
Old Mar 9, 2007 | 07:54 PM
lowill's Avatar
okay thanks dude will check it out tomorrow. this sound is so damn annoying.
Old Mar 10, 2007 | 02:26 PM
98roverguy's Avatar
This is the horn thing I'm referring to. http://www.roversnorth.com/store/pc-...-assembly.aspx
gkubina
LR2
Jul 17, 2011 04:04 PM
inganina
Sep 2, 2009 02:54 PM
inganina
Jul 22, 2009 05:33 PM
primecooler
May 4, 2009 06:04 PM
Snowman
Feb 24, 2007 05:24 PM
