Will a 2002 4.0 plug and play in a 2003 4.6l
Old Oct 23, 2017 | 08:29 AM
dcdiscovery's Avatar
8th Gear
Default Will a 2002 4.0 plug and play in a 2003 4.6l
I just purchased the 2003 knowing it needs a motor. I have found plenty of motors. But my question is since the 03s had the motor issues, would a 2002 4.0l drop right in, and work as everything should(I.e. alarm and electronics)?
Old Oct 23, 2017 | 08:31 AM
Best4x4's Avatar
As long as you get it to match in either the SAI or non SAI config to match your current setup then yes.
Old Oct 23, 2017 | 08:36 AM
8th Gear
Yes I would have to use a sai motor. I knew Sai and non couldn’t inter change I just didn’t know if they changed any of the electronics. This is my first Land Rover but I have been working on cars for years. I just want reliability, next July I am going on a 3000 mile road trip in it with the wife and daughter.
Old Oct 23, 2017 | 08:56 AM
Alex_M's Avatar
100% compatible, and the older the better. I'd get a 99 block if I could.
Then if you were game, you could even switch over the crank and rods from your 4.6 to keep the 4.6 displacement since its the same block, just stroked.
Also if you're willing to pull the heads you can even swap your SAI heads onto a non SAI block.
Old Oct 23, 2017 | 09:15 AM
8th Gear
which vin code would be best? And I like that idea but if I am to go that far I would want to do a complete rebuild while I am in there. Do you know a source for a rebuilt kit I have been coming up blank on my searches?
Old Oct 23, 2017 | 10:03 AM
Alex_M's Avatar
Call up Lucky 8 and they can hook you up. Ask for a forum member discount, too.
Couldn't tell you on the VIN code range. The older the better though. The only problem with the 03-04 blocks is that the machining tools were starting to get worn out. The older you go the fresher all the machining was.
Big Jim Swade
Jun 1, 2021 01:15 PM
ashtray
Jul 2, 2017 07:54 PM
xmarksit
Nov 26, 2013 08:37 AM
willys_49
Nov 10, 2012 07:42 AM
robot808
Sep 9, 2009 02:31 PM
