will D1 locking snout work on D2 transfer case?
Old Dec 26, 2014 | 11:34 AM
jafir's Avatar
It depends on the serial of the transfer case, I think. There are different numbers of teeth.
ALSO a D1 case will not have the hi-lo switch in the front output, which will make the D2 not work with HDC and manual mode.
See here:
https://landroverforums.com/forum/di...non-cdl-52590/
Old Dec 26, 2014 | 06:19 PM
94svt50's Avatar
Thanks for the reply. Time I source the linkage this is starting to get expensive. Maybe I should install a winch instead.
Old Dec 28, 2014 | 07:55 AM
Lowest Bidder's Avatar
See here:
Thanks Jafir, I did not know about the H-N-L switch, I stand corrected.
Just a little precision though, the gears that we see in the picture don't come with the front output housing. They are part of the differential shaft, and match the gears on the secondary shaft. When you replace the front output housing you keep your own differential shaft.
Old Dec 29, 2014 | 02:22 PM
OffroadFrance's Avatar
It's well worth a call to Paul Grant as he has seen this all before no doubt and maybe able to help with the interchangeable parts and a lot of hard earned knowledge and advice.
Old Dec 30, 2014 | 02:59 PM
94svt50's Avatar
Well, cdl it is. $150 after core charge refund. Its out of a 2000 with 77k miles on it. So half the miles I have on my stock one. What seals and gaskets should I change on it while its out on the bench?
Old Dec 30, 2014 | 03:09 PM
ZGPhoto's Avatar
Depends on how in-depth you want to go. GASKET SET LT230 TRANSFER BOX RRC, DEF, RTC3890,RND459, PLD459 - Rovers North - Classic Land Rover Parts
is the whole kit
94svt50
Jan 12, 2015 04:29 PM
blackpaw80
Jul 11, 2013 12:47 AM
mudbug308
Mar 20, 2013 12:12 PM
browndogq
Jan 2, 2008 08:35 PM
johanba
Apr 3, 2007 11:37 AM
