Won’t start - battery ok, starter ok, ignition switch?
I’ve got a 2003 D2 that just died while it was running - I was at a stop and it died and refused to start.
The battery is ok and the starter was replaced somewhat recently. It’s trying to start but it won’t catch. No clicking sounds. Is it the ignition switch? Quick fix? Other things to check?
neuropathy (08-25-2019)
neuropathy (08-26-2019)
Issue Resolved: Crankshaft Position Sensor (CPS) replaced
Thank you, I’m still learning things here. I was able to get the CPS (OEM Bosch part) for $45 and after installing, she’s alive again! Since the issue began a week or two ago, she would start here and there, but would die. I replaced the starter a little while ago, so she really fires up beautifully with a new CPS. Thanks again! Cheers
Best4x4 (08-25-2019)
