Won’t start - battery ok, starter ok, ignition switch?
Old Aug 8, 2019 | 07:05 PM
neuropathy's Avatar
Default Won’t start - battery ok, starter ok, ignition switch?
I’ve got a 2003 D2 that just died while it was running - I was at a stop and it died and refused to start.
The battery is ok and the starter was replaced somewhat recently. It’s trying to start but it won’t catch. No clicking sounds. Is it the ignition switch? Quick fix? Other things to check?
Old Aug 8, 2019 | 09:21 PM
Best4x4's Avatar
Sure sounds like a Crank Position Sensor, see if it cranks once it cools down. An engine needs 3 things to run Air, Fuel, and Spark. If the CPS is INOP it will not have fuel or fire = no run situation.
Old Aug 8, 2019 | 10:38 PM
Frank4's Avatar
X2 on the CPS
Old Aug 9, 2019 | 12:56 AM
shanechevelle's Avatar
Explain clicking sounds...
The engine rotates correct?
Old Aug 25, 2019 | 04:14 PM
neuropathy's Avatar
Default Issue Resolved: Crankshaft Position Sensor (CPS) replaced
Thank you, I’m still learning things here. I was able to get the CPS (OEM Bosch part) for $45 and after installing, she’s alive again! Since the issue began a week or two ago, she would start here and there, but would die. I replaced the starter a little while ago, so she really fires up beautifully with a new CPS. Thanks again! Cheers
mj1672
Feb 29, 2020 02:06 PM
Meldav32
Jul 11, 2017 12:51 PM
bmeier
Feb 19, 2014 10:36 PM
Creed0330
Feb 7, 2012 10:12 PM
eimeo98
Mar 5, 2007 12:07 PM
