Zirc Fittings and shock lube???
Old Apr 5, 2007 | 03:22 PM
drhunter's Avatar
Default Zirc Fittings and shock lube???
My disco 1 94' has been making some souns lately...when I turn the wheel hard while driving slowly the right fron tire make a sort ofclicking sound but when i return the whell the sound goes away. Also, I havebeen going over ALOT of speedbumps lately and have been noticing that the shocks make a shhh sound like they could be lubed possibly.One more thing...When i drive at high speeds there is a whine that develops from about forty on, could it ossibly have somethingto do with the u-joints?? Thanks Guys
Dan
Old Apr 5, 2007 | 05:27 PM
Default RE: Zirc Fittings and shock lube???
Dan, go check and add fluid to your Swivel housings and see if this works, if not, you will most likely need to rebuild the right swivek and CV joint.
If the noise goes away you might consider switching to Rovers new grease pouches instead of gear oil, protects longer and less chance of leakage.
Mike
Old Apr 5, 2007 | 06:10 PM
drhunter's Avatar
where do i add fluid to the swivel housings?? can i use regular oil?
Old Apr 5, 2007 | 09:31 PM
Go look at the swivel joints, you will see to plugs, open the top plug and if np oil comes out fill it with 80/90W gear oil.
Mike
Love U Landie
Feb 4, 2013 03:17 PM
kingsly
Jul 15, 2010 08:00 PM
Danny Lee 97 Disco
Apr 3, 2010 08:40 PM
ljdiscovery
Jul 18, 2008 08:51 PM
