Discovery 2 LS Conversion
#1421
Wanted to thank you all / forum for all of the amazing information that was such a huge help through this swap. Just had tune completed and no warning lights! This is especially noteworthy for my mediocre driveway mechanic skills.
Did my first freeway drive and what a difference being able to merge in traffic and be at 75 pretty effortlessly.
Do have a few remaining issues to work through.
- Temp is solid at 208, local stop and go traffic, on the freeway at 75 with ambient temp in the high 80s. When I turn the A/C temps slowly rise, at 224 I turn the AC off and temperature slowly returns to 208.
- Wide open throttle issue, looking closely at CPTKAOS latest post and pics.
- small leak on the high pressure steering line.
- finding a place for the GM harness fuse box in the interior and overall wiring cleanup / management.
Look forward to getting some miles on.
L33 5.3 Long Block crate motor.
#1422
#1424
#1425
Look forward to your next update !
#1426
Thanks for the info Rynoman1. Hear you on the lights blocking radiator. Interesting that the allisport radiator didn’t help temps much. I’ve always wanted one!
Had a Flowkooler pump in the Rover motor along with the 2991 Hayden and was happy with the cooling. Hated how loud it was though.
Hoping the electric fan setup with the LS would be a good option. Tuner I’m using changed it from single fan to dual and has a few ideas. So hopefully we’ll figure out why temps climb with A/C on.
#1427
#1429
#1430
I have the 16842 model. I had to clearance some of the plastic on one of the fans to get it to slide past the waterpump snout. And I drilled out the shroud rivers to pinch it a littl where it meets the radiator. Fits perfect. Today at 82 degrees with the ac on its running 198 sitting in mild traffic.
04disco2va (05-07-2023)
