Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old Mar 16, 2019 | 09:38 AM
  #291
OakBehringer's Avatar
Will the LS Swap improve highway performance, in regards to cruising speeds? I’d like to be able to cruise at 75-80 al day long.
Scenario 1: With the LS, small lift, larger tires, no regear - the cruising rpms would be lower. Increased power would allow it to sustain this scenario.
Scenario 2: Just the LS - stock-ish size tires, LS can simply (safely) cruise at higher RPMs.
Old Mar 16, 2019 | 03:24 PM
  #292
ACEngineer's Avatar
Originally Posted by NVDiscovery
Curious what exhaust system you are using for the LS installation?
Everything including the cats back is standard Land Rover (the truck in the video above had a resonator delete).
The biggest problem with the factory engine in the Florida heat was the engine would get warm if sitting at a sustained 70+ mph cruise with the A/C on. That problem is rectified with the LS and there have not been issues with sustained high-speed cruising. Either of your scenarios should be fine. Since a 2 inch lift is really needed with the conversion, scenario 1 would probably be preferable.
Old Mar 17, 2019 | 09:30 AM
  #293
ACEngineer's Avatar
Picked up a pair of 5.3L LM7 engines for $400 each. These have the iron block with aluminum heads, but they were in great condition. It turns out one of them was recently remanufactured (stickers still on the block and all) and looks to have only been running for a few thousand miles before the truck was crashed -- quite a find!
Old Mar 17, 2019 | 03:50 PM
  #294
PosterNutbag's Avatar
Killer deal. I should start scoping around FL for one so that I’m ready to go. Were those local to Ft.Myers?
Old Mar 17, 2019 | 11:14 PM
  #295
ACEngineer's Avatar
These came from a junkyard in Lakeland -- very nice and friendly people. It was our first time using them, but seeing as how things turned out, we're planning on using them in the future. They had about 20+ LS engines ready to go and said that they could do the full dropouts with the computer/harness/etc if we needed them for a competitive price. I'll forward along the contact info if you send me an email.
Old Mar 19, 2019 | 03:01 PM
  #296
knucklehead_vol's Avatar
So how much is this kit?
Old Mar 20, 2019 | 07:14 AM
  #297
The_OGCJR's Avatar
pricing hasnt been determined yet. They are still in development
Old Mar 20, 2019 | 09:49 AM
  #298
stereophile33's Avatar
ACE are you taking deposits yet 😜😇
Old Mar 21, 2019 | 12:09 PM
  #299
hnandez's Avatar
This is awesome. It's given me new hope for the long term viability of my disco. I'll be watching this thread.
Old Mar 26, 2019 | 05:51 PM
  #300
2002 beast's Avatar
Hey Ace how's the temperature running with the factory radiator my d2 got a lot of weight to pull around it's sitting on 37's and I plan on doing some trail riding with it just wondering on the temperature
