60k Mile Service!
Old Feb 3, 2010 | 12:45 PM
stankonia20's Avatar
Default 60k Mile Service!
Can someone give me some 411 on this?
Price and what exactly is done to my vehicle!
Thanks for the info In advance!
Almost forgot....
I have an 03 Range Rover HSE
Old Feb 5, 2010 | 06:04 AM
Rovin4life's Avatar
lof,change air filter, change pollen filter, change spark plugs, change coolant, rotate tires, reset maintenance light. look over vehicle for any problems like bad tie rods or coolant leaks like a radiator or hose.
Old Feb 6, 2010 | 12:47 AM
LRScott's Avatar
Your owners manual will give you a list of things that need to be done at 50k miles. Either verify that the service has been done, or get it done yourself.
Old Feb 6, 2010 | 08:51 AM
In addition, all though it is not called for in the manual, you should change "ALL" fluids. Rovers have had lots of tranny/dif. and t-case issues because they don't suggest fluid changes.
Also use only synthetic fluid for extra protection.
Old Feb 7, 2010 | 05:18 PM
Thanks for the info. My dealership quoted me @ about $1k?
Old Feb 7, 2010 | 10:11 PM
LRScott's Avatar
OMG. Go to a local shop that works on rovers and or bmws (since your rover has a 4.4L bmw engine) and have it done. Its not that hard... Then take the money you saved and go on a vacation.
Old Feb 8, 2010 | 08:51 AM
Yea I figured they were overcharging me! I think its time for me to find a new dealership to go 2!
Earlier this winter my air suspension was inactive, I took it to the dealership they fixed it.
One week later my Air suspension went out again! In my Opinion I feel the dealership is sub par!
Old Feb 19, 2010 | 01:14 AM
cold_surfer's Avatar
Default trans
the trans change requires dropping the exhaust Ypipe and removing the cross member on the RRC to fully remove the trans filter. If they don't do that then they didn't change that filter and you paid for nothing. Just for fun hit the bolts with silver or black $.99 krylon spray paint and see if they even turned the bolts. It will be VERY obvious if they do remove the pan. If they didn't -- BUSTED and DONT pay the bill -- at ANY shop...
spray the pan bolts that is.... they should also be changing the gasket, which is visible too.
Old Feb 19, 2010 | 06:15 AM
Rovin4life's Avatar
Mike, Range Rovers don't have the same crap that yours does. Stick with what is there and he will be fine. No need to change the diffs and the transfercase until it says so.
Besides I have seen many of the bmw range rovers go 100k with no issues other then some oil leaks in the engine and coolant leaks.
electrical crap inside not considering.
kcferna
Jul 7, 2009 08:33 AM
Disco Girl
Jan 17, 2009 05:06 PM
theMar
Freelander
Dec 25, 2008 07:56 PM
mwyrick45
Oct 31, 2008 12:23 PM
brooksa
Jan 22, 2008 08:56 AM
