Did the swap, now need help...
I swapped out my 4.6 with a 4.0 from another Range Rover. Everything is hooked up and it will crank but I do not get any spark. I used the wire harness from the 4.0 and hooked it into the 4.6 ECU. I have chased every where for the source that the coils use but I have not found it. I know it is not normal to do this but here I am.
Any help you can give is greatly appreciated.
I never got my ecu remapped but it should still start. One thing i didn't do was change the wiring harness i used the 4.6 harness. I would just recommend just tracing your steps to see if you missed a sensor hook up which should be the logical answer.
But when you bought the engine did you hear it run or know that it would start before you bought it?
I heard it run and so that is why I was lost. I found that I must have damaged the crank sensor when I transported it. I replaced it and it fired right up. Drove it about 300 miles today and it worked great. I did not have to swap the wire harness over at all so that was nice.
All and all I am into this Rover only $2700 so I think it worked out in my favor, thanks for all your help. I love this forum.
Gr8lite
08-07-2010 07:04 PM
03discoman
08-04-2009 03:23 PM
handsome rob
02-15-2009 11:54 PM
