Did the swap, now need help...
Old Feb 16, 2009 | 12:05 AM
handsome rob's Avatar
Default Did the swap, now need help...
I swapped out my 4.6 with a 4.0 from another Range Rover. Everything is hooked up and it will crank but I do not get any spark. I used the wire harness from the 4.0 and hooked it into the 4.6 ECU. I have chased every where for the source that the coils use but I have not found it. I know it is not normal to do this but here I am.
Any help you can give is greatly appreciated.
Old Feb 17, 2009 | 05:35 AM
xb70valkarye's Avatar
Might be wrong but I think your ECU needs to be sent off to me remapped to work with a 4.0.
Why did you swap it out? Do you still have the 4.6? What year is the 4.6?
Fred
Old Feb 17, 2009 | 11:48 AM
Jasondizzyd's Avatar
I never got my ecu remapped but it should still start. One thing i didn't do was change the wiring harness i used the 4.6 harness. I would just recommend just tracing your steps to see if you missed a sensor hook up which should be the logical answer.
But when you bought the engine did you hear it run or know that it would start before you bought it?
Old Feb 17, 2009 | 04:17 PM
I agree, should use the 4.6 harness. As for the no start/ no spark, was the crank sensor damaged on the 4.0? This would cause a no spark oand or no fuel issue?
Old Feb 18, 2009 | 01:05 AM
I heard it run and so that is why I was lost. I found that I must have damaged the crank sensor when I transported it. I replaced it and it fired right up. Drove it about 300 miles today and it worked great. I did not have to swap the wire harness over at all so that was nice.
All and all I am into this Rover only $2700 so I think it worked out in my favor, thanks for all your help. I love this forum.
caymandrew
Apr 20, 2013 10:08 PM
photocrimes
Feb 27, 2011 09:22 PM
Gr8lite
Aug 7, 2010 07:04 PM
handsome rob
Feb 15, 2009 11:54 PM
