Electrical gremlin - need help
Old Apr 13, 2012 | 10:11 AM
Gojobby's Avatar
5th Gear
Default Electrical gremlin - need help
Left my key on for 3 hours and now GPS screen is white and will not turn off - also can not adjust radio volume. Is there a reset for this?
Thanks.
Old Apr 13, 2012 | 01:14 PM
socalrovershop's Avatar
what year ? try disconnecting the battery for couple minutes and then retry
Old Apr 13, 2012 | 03:51 PM
Gojobby's Avatar
5th Gear
Thanks - will give it a try. In searching the forum this appears to be a common problem, usually when replacing the battery. Seems like their should be a simple solution.
By the way it is an 02 P38.
Old Apr 16, 2012 | 10:03 AM
Gojobby's Avatar
5th Gear
Did not cure the problem - any other suggestions?
Old Apr 16, 2012 | 11:55 AM
Try same practice again with head lights on, in theory the extra load of the head lights sometimes bleeds off small charges in the electrical system.
Old Apr 19, 2012 | 06:44 PM
Gojobby's Avatar
5th Gear
Pulled up a UK forum last night - this is a common problem - if disconnecting the battery and fuse does not solve the problem then the sat nav module is bad. Disconnected it and solved all my problems except no longer have nav which I never used. Saw a salvage unit on ebay for $189.
Thanks for everyone's help.
ashtray
Audio/Visual Electronics
Nov 19, 2014 06:56 AM
TenMan1
Jul 31, 2011 10:32 PM
A Team
Jun 15, 2009 07:16 PM
bode61
Oct 1, 2007 09:45 PM
dumellarah
Feb 24, 2007 03:40 PM
