No power steering at all
G'day from Oz. Newbie, first post.
My old 81 has served me well for 30 years but ... its been 30 years!
Steering is like a dodgem car - can spin the wheel with my little pinky, such is how light it is. Nightmare to drive and dangerous. Got a another 3-bolt steering box from a retiring Rangie mechanic (wouldn't guarantee the box but said no reason why it shouldn't be fine), put it in, and there's zero power assistance. No extra noise from the pump as if trying hard, no loose drive belt, no binding column uni's, just no power assistance, as if the pump was disconnected. Now the pump maybe suss but would seem unlikely since it worked so well on the old box. My theory is that the replacement box, having sat idle for the last few years, has a stuck piston or valve or something, and I should maybe start with a fluid cleanout and some Lucas P/S additive. What do we all think? Or maybe should I try to fix the too loose original box, but then I'm not sure if I'm up to that or can justify the expense.
Thanks
Kanoof
81 2-door 600,00+k too old to spend money on, too much a member of the family to let die.
Thanks
Kanoof
I mis-understood. Not having documents for that model, if one assumes the problem is too much pressure (stuck valve, etc.) - could that be confirmed by removing the power steering pump belt for a very short test. Flush the fluid that is in the box/PS pump system (maybe the trash will wash out). Just about all of the trucks have an adjustment nut that will tighten up the steering, but that is more for the wheel turns too far to make small changes in vehicle direction.
DiscoBritney
12-19-2011 06:24 PM
bcolins
05-10-2011 11:09 AM
losinov
03-21-2011 08:57 PM
jycsalas
04-17-2009 02:21 AM
