Pressure bleeding brakes ok on p38???
Old Oct 20, 2012 | 06:09 PM
wastedincome's Avatar
Default Pressure bleeding brakes ok on p38???
Title sums it up. Just replaced ABS pump and need to bleed the brake system. I typically use my pressure bleeder on my other cars and wanted to be sure its ok to use on the p38
Old Oct 20, 2012 | 09:19 PM
LRScott's Avatar
Here is the procedure, kind of a PIA: ABS Brake Bleeding Procedure Range Rover 4.0/4.6
Also, run your pump with the output (high pressure) side disconnected. Make sure it is flowing properly. I ended up replacing my pump because the accumulator failed in an unusual way, leading me to believe it was the pump itself. It turned out that the brake fluid reservoir was so clogged up that the pump couldn't draw fluid from it, and ruined the accumulator by pumping air into it.
Old Oct 21, 2012 | 02:22 PM
What a PITA, I didn't really follow instructions properly ( I should know better) SO sounds like I need to start all over I drained and flushed the reservoir out and was some of the nastiest fluid I've ever seen.
Old Oct 22, 2012 | 08:07 AM
04duxlr's Avatar
The reservoir in these things has very fine screensin places that you can't get to, and if the fluid isn't changed often enough it makes a nice yellowy sludge that plugs them up. Flushing the screens is almost impossible.
As for the bleeding, you need to follow the procedure. The brakes in these vehicles operate unlike any other so normal techniques don't work.
Old Oct 22, 2012 | 09:00 AM
Rovin4life's Avatar
The brake system is similar to diesel engine trucks. The procedure has to be performed or else. No other way around it. Trust me. Seen guys think they are smarter and screw themselves.
Old Oct 22, 2012 | 02:36 PM
The fluid was darker then any beer I'd drink, damn near Guinness looking I'm now realizing that this p38 brake system is unlike anything I've wrenched on. The procedure list seems more complex the a engine build.
Old Oct 22, 2012 | 02:37 PM
Yup, Guess I need to print the procedure out and take a DAY to do it over PROPERLY
Old Oct 25, 2012 | 08:45 PM
98NiagaraRR's Avatar
Took the question right out of my mouth. Good thing I didnt try the pressure bleeding that I was planning to do.
Old Oct 26, 2012 | 09:03 AM
Rovin4life's Avatar
The simple bleeding you do on those with a new set of brake pads is simply turn on the vehicle and let the pump run until new fluid comes out and just keep putting new fluid in. You just need to have some press the brake pedal to activate the pump.
Old Oct 28, 2012 | 08:14 AM
UPDATE: I took the time and followed the proper procedure yesterday and it seemed to go very smoothly!!!! I managed to get a bunch of air out of lines I thought were good Thanks for all the advice and help Rover lovers
FightOnUSC79
Nov 26, 2010 09:43 AM
rbruton
Other
Oct 6, 2010 09:12 AM
caleb
Nov 28, 2008 08:11 AM
dillhole
Jun 26, 2008 09:13 AM
skewett
Jul 8, 2007 11:28 AM
