03 Disco-Misfire
03 Disco-Misfire
03 Disco-95K miles-OBD Code indicates a misfire in #1 cylinder. Came on very suddenly. No apparent issue with plug or wires.Haverun system cleaner through fuel system and crankcase (oil additive)to no avial.Any thoughts/ideas?[I have received multiple "suggestions" fromvarious "professionals"]. Thanks.
RE: 03 Disco-Misfire
Mike
45K. Ibought it used so I can't speak for the first 90K.Since I have owned it, I have used premium (92). Yes, I have had it decarboned. It also was dealer serviced on all but two regular (minor)service/maintenance intervals. The only major one skipped was the 90K service (which does call for complete tune-up with new plugs & wires, along other items).
spA
spA
on
I would suggest you replace the plugs and wires along with a good induction service.
Do you like to work on the truck, if so we should talk and I can run you thru what to do and what parts to use.
Send me an e-mail with your tele number and I would be glad to call you.
Mike
mikeljacobs@comcast.net
Mike
Disco Mike-As it turns out....I was very misinformed (sticking valve)by the mechanic who originally looked at my Disco. Turned out that on three of the plugs, the electrode had been completely burned off, the others were not much better. Additionally, the plug wires crumbled in your hand. After installing new plugs and wires, misfire dissappeared and truck is now running well. He also knew of the CV issue and has replacements in stock. Thanks again for all your advise and help. If I ever need additional help, I now know where to start.
spA
spA
