Sponsored by: CARiD
03 Disco-Misfire
Old Jan 6, 2007 | 01:31 AM
Fat Tony's Avatar
4th Gear
Default 03 Disco-Misfire
03 Disco-95K miles-OBD Code indicates a misfire in #1 cylinder. Came on very suddenly. No apparent issue with plug or wires.Haverun system cleaner through fuel system and crankcase (oil additive)to no avial.Any thoughts/ideas?[I have received multiple "suggestions" fromvarious "professionals"]. Thanks.
Old Jan 6, 2007 | 09:39 AM
Default RE: 03 Disco-Misfire
How many miles on the trucks plugs and the plug wires?
What octane gas do you run and have you ever decarboned the engine?
Mike
Old Jan 6, 2007 | 11:26 AM
Fat Tony's Avatar
4th Gear
Mike
45K. Ibought it used so I can't speak for the first 90K.Since I have owned it, I have used premium (92). Yes, I have had it decarboned. It also was dealer serviced on all but two regular (minor)service/maintenance intervals. The only major one skipped was the 90K service (which does call for complete tune-up with new plugs & wires, along other items).
spA
Old Jan 6, 2007 | 11:49 AM
I would suggest you replace the plugs and wires along with a good induction service.
Do you like to work on the truck, if so we should talk and I can run you thru what to do and what parts to use.
Send me an e-mail with your tele number and I would be glad to call you.
Mike
mikeljacobs@comcast.net
Old Jan 6, 2007 | 12:29 PM
Fat Tony's Avatar
4th Gear
I may have had my fill of home repairs on the '97 I just traded out. I would like to discuss this issue/problem/solution in greater detail, however. Contact information has been forwarded as indicated.
Old Jan 13, 2007 | 05:30 PM
Fat Tony's Avatar
4th Gear
Disco Mike-As it turns out....I was very misinformed (sticking valve)by the mechanic who originally looked at my Disco. Turned out that on three of the plugs, the electrode had been completely burned off, the others were not much better. Additionally, the plug wires crumbled in your hand. After installing new plugs and wires, misfire dissappeared and truck is now running well. He also knew of the CV issue and has replacements in stock. Thanks again for all your advise and help. If I ever need additional help, I now know where to start.
spA
Old Jan 13, 2007 | 06:05 PM
Glad to hear that worked out, don't let the u-joint/ constantant velocity joint go too long.
Mike
Gromeo
Jan 24, 2013 03:41 PM
FJL
Jan 24, 2008 12:26 PM
RYANHASADD
Dec 15, 2007 03:37 PM
tbesselman
Nov 17, 2006 01:20 AM
tbesselman
Jun 1, 2005 01:54 PM
