Sponsored by: CARiD
2001 4.6 HSE hood won't open
Old Jan 18, 2008 | 08:06 PM
rjmaype's Avatar
3rd Gear
Default 2001 4.6 HSE hood won't open
Under dach lever operates but hood does not pop up.
Front center hood lever will not release.
Any suggestions?
Old Jan 19, 2008 | 07:54 AM
Default RE: 2001 4.6 HSE hood won't open
Try getting to the hood release cable thru the grille with a pair of pliars or take it to the shop and get a new cable installed.
Old Jan 21, 2008 | 08:41 PM
lrobin3w's Avatar
there are two hood latches left and right.
Old Jan 21, 2008 | 11:26 PM
climbskiroverguy's Avatar
i have the same problem with my disco1, i was told its just buildup of crud in the cable housing, and possibly the tension of the release spring has been compromised
Old Jan 21, 2008 | 11:49 PM
WolfPack's Avatar
Same problem on my Blazer. Just WD 40 the latch mechanism and let it soak for a good few minutes. Then try and pop it again and fiddle with the latch. If all that doesn't work, take Disco Mikes advice, and get a shop to put in a new linkage.
steveo2000
Sep 8, 2015 08:00 AM
bmxermike
Dec 31, 2010 12:57 AM
Dino76
Sep 7, 2007 04:37 PM
benedmonson
Apr 10, 2007 01:45 PM
psyduck125
Jan 29, 2007 12:54 AM
