Sponsored by: CARiD
2007 lr3 front ac doesnt work rear does.
Old Jul 12, 2012 | 09:23 PM
Gray8188's Avatar
Default 2007 lr3 front ac doesnt work rear does.
Hey guys I'm new on here my parents have a 2007 lr3 and are having some issues with the ac. I haven't looked at it myself but they said it was working then they shut the car off and tuned it back on and only the rear air works. Nothing in the front. Not sure if this is a common issue. I'm going to try to get over there and look at it soon. Is this a known issue? Thanks Grayson.
Old Jul 12, 2012 | 09:37 PM
Rear blower fuse is 22E in battery junction box, front unit is fuse LINK 12E in same box.
Old Jul 12, 2012 | 09:49 PM
Gray8188's Avatar
Awesome thank you I will check those tomm and report back. Hopefully its that simple. The vehicle has been having nothing but issues lately.
Old Jul 12, 2012 | 09:53 PM
Gray8188's Avatar
What part of savannah do you live in? I lived in the landings before I moved to fl. I still have family there and go to tybee all the time.
Old Jul 14, 2012 | 12:08 PM
Gray8188's Avatar
We checked all the fuses they all appear to be fine. Anything else you think it could be? trying to avoid taking this thing to the stealership.
Old Jul 14, 2012 | 12:27 PM
Bkreutz's Avatar
Appear to be good?, hard to see electricity so it's best to test fuses with either an ohmmeter with the fuse removed or a voltmeter with the fuse in place and the circuit active. I've had (multiple times) fuses that appear good but are not.
Old Jul 14, 2012 | 12:30 PM
Gray8188's Avatar
We switched fuses, and tried different ones. They all worked fine.
Old Jul 14, 2012 | 01:32 PM
Rovin4life's Avatar
check to see if the blower motor and blower motor resistor isn't melted. if its melted you need a harness. its under the passenger side.
Old Jul 14, 2012 | 08:33 PM
Gray8188's Avatar
Okay thanks I'll check that out and report back with what I find.
Deaton1076
Sep 9, 2013 10:49 PM
mbarela
Jan 13, 2011 05:19 PM
jeffmalone
Mar 13, 2010 09:23 PM
landRoverNewbie
Oct 13, 2009 12:26 PM
battsup
Jul 16, 2005 09:23 PM
