Sponsored by: CARiD
95 Discover Power Steering fluid
Old Jan 22, 2013 | 10:12 PM
jaw7091987's Avatar
8th Gear
Default 95 Discover Power Steering fluid
Hey all,
My power steering fluid has been getting low, below dip-stick indicator even. I believe I have a slow leak, I last topped off last July or so.
Anyway, my question is, the manual says to use PS Fluid Dexron 2, but I could not find the information indicated on the fluid I purchased.
Super Tech Power Steering Fluid, 32 oz: Automotive : Walmart.com
Would this be okay to use with 95 Discovery? It is clear and the fluid in the reservoir is black, but it mentions it mixes with other brands.
I am low on funds so if I can safely use this, that would be dandy. Any advice is very welcome.
Thank you very much
Old Jan 23, 2013 | 12:37 AM
Nope. The RAVE shop manuals say ATF Dexron II. Use automatic transmission fluid. Take what you bought back to wally world, get refund, buy ATF. Note - your fluid should be red, not black. If old and black you'l need to save up a little to have enough fluid to change it out.
Old Jan 23, 2013 | 01:13 AM
jaw7091987's Avatar
8th Gear
Thank you Savannah, this is the second time I count you've come to my rescue I am glad I had that moment of "Before the pour" second thoughts. lol
Y'all are great
Old Jan 23, 2013 | 09:29 PM
Buy Valvoline MaxLife ATF, it has seal conditioners in it to help stop leaks.
Just keep topping off the system with that until the leak stops.
Old Jan 23, 2013 | 10:01 PM
antichrist's Avatar
The owners manual has all the fluid specs. If you don't have one it's on the RAVE CD.
You may have a little trouble finding just Dexron II these days, but it will say on the back that if it is ok for Dexron II use.
For instance I use the Castrol Multi-Vehicle ATF. The Castrol Dexron VI ATF is also suitable.
Old Apr 22, 2013 | 11:04 PM
CarlDisco's Avatar
4th Gear
Default Thank you!!!!!!!!!!
My '96 Disco had been leaking power steering fluid for two years. Every week I would replenish her with a new bottle. It was a weekly ritual.
Then I finally googled this issue and found this page. I'm a moron for not doing so earlier. I honestly thought this is just what these cars do!
I quickly went to the store and bought Valvoline ATF and put in about half the bottle. A week later, the empty power steering sound was back ('eeeeeeeerrrrrrrrrrrrr'), but I expected this because the previous power steering fluid was still in there (but now had hopefully completely leaked out). I filled her up with the rest of the ATF and crossed my fingers.
That was two weeks ago. And the sound hasn't come back!
Such a relief. And I swear - she's turning more smoothly than ever.
Now I know what to do net time the fluid gets low.
Thank you so much to all of you for all your posts!
I love my car
Old Apr 23, 2013 | 12:21 AM
At least you are checking under the hood weekly, which all of us should be doing with our trucks.
jycsalas
Apr 17, 2009 02:21 AM
willlane
Nov 10, 2007 07:33 PM
jdelp
Oct 3, 2007 11:05 AM
discoken
Jul 4, 2007 05:29 PM
nanin
May 12, 2007 10:09 AM
