Sponsored by: CARiD
ABS
Old Jun 18, 2007 | 10:18 AM
DetroitRover's Avatar
Default ABS
The ABS dash light is on on my 90 Rover Classic. I can here the ABS pump cycle, and am pretty sure it works, though the ABS does not activate when needed. Any suggestions to what I should check first on this one without having to remove each wheel hub to check the sensors?
Cheers,
Old Jun 18, 2007 | 12:46 PM
Default RE: ABS
Is the pump running more then normal. A common problem with the early ABS was the accumulator failing and not storing power.
Mike
Old Jun 19, 2007 | 09:28 AM
Default RE: ABS
My pump is not running more than normal from what I can tell. How do I check to see if the accumulater is functioning? Or is it likely that it is ready for replacement. I have 135k miles on this vehicle.
Thanks for your help.
Cheers,
Glenn
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
