Sponsored by: CARiD
ABS Pump Seized-belt mod
Old Dec 29, 2010 | 03:15 PM
Newfie Rider's Avatar
4wd High
Default ABS Pump Seized-belt mod
Ran into some trouble with the New to me 2000 Disco.
ABS pump siezed, and couldn't use the original serpentine belt.
Unbolted the ABS pump and tied it back using zip ties to the engine 'eye'lift.
After many changes of belt at a local auto parts place, I found the size belt to get me home.
93.5 inches 7 rib will work. Hope some else finds this useful, took me 5 belt changes till I found the correct size
Old Dec 29, 2010 | 07:10 PM
lordmorpheus's Avatar
ABS pump? I am trying to imagine which pump you are talking about. Is this the pump above the power steering pump, and next to the A/C compressor?
Old Dec 30, 2010 | 02:52 PM
4wd High
Dooh, downloaded the manual today. It is actually the ACE pump. I seen it connected to the Brake resivoir and assumed it had something directly to do with the operation with the brakes.
I am hoping that I can operate the Disco with this disconnected
batiscan
May 24, 2010 09:04 PM
Noah360
Sep 6, 2009 10:05 PM
Malave99
Jun 30, 2009 03:20 PM
JBEGIN
Jun 29, 2009 02:12 PM
fpapai
Oct 29, 2007 12:30 PM
