Sponsored by: CARiD
Can anyone explain "NO 2 FREEWHEEL"
Old Aug 19, 2012 | 11:34 AM
LR Techniker's Avatar
I would not bother!
Old Aug 19, 2012 | 12:44 PM
demson's Avatar
Default No 2 freewheel = no sprag
So I'm assuming "no 2 freewheel" means no sprag clutch and does this mean a pressure test will gain no more knowledge? or can it be possible that sprag clutch is sticking, if thats even possible, and fluid/ filter change could resolve the problem?
Old Aug 19, 2012 | 12:52 PM
In this case a fluid/filter change is not going to help much. Won't hurt anything to change it except your bank balance. You descriptions match results from several sources, maybe think about a used tranny, salvage yards sell them fairly cheap (like under $150). But you still need a place to work on it or pay a shop, who will of course not warranty the used tranny. Start saving up for it. DIY rebuild of ZF 22 tranny not a weekend project.
Old Apr 19, 2020 | 06:00 PM
Wally Herron's Avatar
Default Sprag clutch
Originally Posted by LR Techniker
I would be curious to see how long the transmission lasts by "bypassing" the clutch at each take off. IMHO, the clutch wasn't designed to pull the full load of the vehicle, that was the job of the sprag, so if it is really doing any damage or not, is hard to say.
so mine does the 1st to drive thing. Sometime it will go starting in drive but will not offer over drive. There is a loud whining noise in d, 3, and 2. (Almost sounds like a pump) when you shift into 1 it goes away. Any thoughts? So my question could be to the others to any whining or pump noise?? Also did the filter change and fluid this weekend.. old fluid brown and foamy.. don’t know why that is either. 106k miles on 03 disco 2
Old May 6, 2020 | 10:19 PM
martinoermando's Avatar
7th Gear
Originally Posted by demson
Just bought a 97 disco. Transmission will only let me start in 1st and once im going everything works fine until i come to a stop then i must go back to 1st to start moving again. Online Manuel says i have "no 2 freewheel" not sure what that means. just put in some
Nox Vidmate VLC Lubegaurd but hasn't helped yet. Any suggestions would be appreciated.
You will need it rebuild ASAP, as it was not designed to pull the vehicle, only to work with the sprag to provide engine braking.
longtallsally
Feb 12, 2019 08:15 AM
attworth
Jul 26, 2018 11:27 AM
nadylime
Oct 24, 2012 09:45 AM
calebbo
Oct 12, 2011 01:19 PM
primesuspect
Sep 4, 2011 11:56 AM
