Sponsored by: CARiD
That 'clunck' when stationary shifting gears. (98 Disco)
Old Dec 30, 2013 | 11:57 PM
tre soli's Avatar
3rd Gear
Default That 'clunck' when stationary shifting gears. (98 Disco)
Hi all:
Could use someone's expertise who's experienced this issue before or knows of it. I have a 98 Disco with roughly 140k on it. When I come to a stop to do into reverse, let's say to park, I can hear strong 'clunk' sound. It can be felt a little too. It seems to come from the transfer case? What are your thoughts? Front or rear driveshaft? U joints? Transfer case issue?
If it helps, full transmission fluid/filter change in 2011. Just this past month did transfer case, engine, and both front and rear diff fluids. Still hear and feel that 'clunk' when coming to a stop and changing into reverse. Or back into drive.
Let me know! Thanks!!!
Old Dec 31, 2013 | 09:41 AM
fishEH's Avatar
So you have a CLUNK when shifting from P to R and/or P to D? It wouldn't hurt to check your Ujoints, but more than likely it is just normal Disco slop. They all have it, some worse than others.
Old Dec 31, 2013 | 10:14 AM
drowssap's Avatar
x2 check your Ujoints
Old Dec 31, 2013 | 10:23 AM
abran's Avatar
I have the same clunk. Never thought anything about, figured it was "normal disco slop". Now you got me thinking...
Are you 2 referring to the u joints on the front and rear driveshafts?
Old Jan 1, 2014 | 12:40 AM
tre soli's Avatar
3rd Gear
Thanks! Doing a little more research I think you guys are right. Turns out the u-joints are pretty common for that problem. Manually checking for play on both the front and rear driveshafts. I'll be replacing the u-joints and see if it tightens things up. I'll repost when I do if this thread is still up and let you know how it worked out!
TheoPalvi
Jan 26, 2011 07:45 PM
meltdowndave
Jan 5, 2009 08:47 PM
sosico
Dec 31, 2008 06:35 PM
Acer
Mar 29, 2005 07:27 PM
