Sponsored by: CARiD
Dealer won't service older vehicles
Old Feb 28, 2019 | 01:48 PM
Disco203's Avatar
So, I purchased the Gap IID tool and have updated the transmission software.. still getting the "suspension fault traction compromised" warning (bu no fault codes showing up on the tool, and function seems to be normal). Also, I can't access the special programs (terrain response), which I assume is related. I tried a hard reset, all to no avail. Any advise would be greatly appreciated.
Old Feb 28, 2019 | 04:46 PM
DavC's Avatar
A good dealer would service your car. I had a pretty good relationship with mine (still do I imagine, just don't spend money at the service center as much with even older cars).
As far as I would know, I bet they would service even a rest of world 110 or my 95 disco, but I understand their feeling like what if they break something as they try to fix something else? I used to have a 2006 LR3 dealer serviced for a lot of big ticket stuff, never had an issue with them taking it.
Old Mar 6, 2019 | 04:41 PM
The Deputy's Avatar
I've worked on all four of my Discovery ll's...and l can truly understand "why" they wouldn't want to do it...lol.
Good luck, with your issue.
​​​​​​​ Brian.
Old Apr 10, 2019 | 10:46 AM
Disco203's Avatar
Update: So, I took ArmyRover's advice and bought the Gap tool, and was able to get everything sorted out (after replacing the Arnott compreessor which was under warranty). Updated all ECU's, diagnosed purge valve issue, and even programmed a new key! It's a great tool and the customer service and user manual is also excellent. Thanks to all for the advice. Happy to have a (for now) well sorted LR.
Old Apr 16, 2019 | 01:11 PM
guy's Avatar
guy
My dealer is awesome. Sorry its not the same for you. Just got a new engine, turbo and some suspension bits on a 2014 LR2... pro bono.
Old Jul 9, 2024 | 12:20 PM
Norman-LR's Avatar
Originally Posted by No Doubt
Once cars pass a certain age or mileage point (which varies a bit for every model), dealers fear that something can naturally break during their service time.
Imagine taking in a Disco 2 for a head gasket job. Dealership fixes it. You get the Disco back and the CPS sensor dies in the lot. Then one of the door locks fails. You push it back into the service bay.
Sometimes, customers will blame the dealership for those additional failures.
So dealerships simply stop taking older vehicles for service unless the customer also has newer vehicles and a reputation with the dealership.
Older vehicles are simply not compatible with new car dealers. Old car owners must have a different mindset to survive without dealer help.
Same problem in NJ . . . LR dealership says they are incapable of servicing an LR because it is older
Old Jul 10, 2024 | 09:48 AM
Elzot's Avatar
That's pretty asinine in my view. Every business has risks and reasonable ways to limit them.
When I took my 2016 Audi to my very good independent for at transmission code, he simply advised me that, while he can replace the offending part, it is a fact that with Audis, fixing some things sometimes results in other problems popping up, even seemingly unrelated items and, that while he would be able to handle anything that should occur, he wants to make it clear that he cannot be held responsible for those things.
The fact that a dealer refuses to work on two-year old cars that they sell tells me they are hiring brake jockeys, not true mechanics. Or they simply want to do the high profit, quick turn-around services.
gillart
Jul 11, 2024 01:08 PM
Jordanpryce
Dec 21, 2011 08:20 PM
demonlarry
Aug 22, 2011 10:07 PM
deadpass
Aug 13, 2011 11:04 AM
honda90
Mar 5, 2010 06:46 AM
