Sponsored by: CARiD
Electrical issues
Old Apr 14, 2012 | 09:08 PM
Ajs5691's Avatar
3rd Gear
Default Electrical issues
Hey guys,
I have a 2005 lr3 . I was changing the license plate bulbs to led 's today. When I turned the the lights on the whole driver's side was out. The brake, headlight,and turn signal all work, but the parking and daytime running lights on drivers side are now out. I checked the fuses and bulbs and everything looks fine....I disconnected battery and still nothing.....any suggestions?????
Old Apr 14, 2012 | 10:29 PM
Perhaps you disturbed a ground point, or a fuse link (controls more things, but better to check with a meter. Here's a link to a source for free (but slow) download of the factory set of manuals, it does have electrical diagrams. I'm not on the home PC at the moment, I'll look when it get there later tonite and provide an update if I see anything.
See https://landroverforums.com/forum/lr...ownload-48834/
Old Apr 14, 2012 | 11:53 PM
See these 3 pages from the manual set - the thrid pages shows the plate light is also fed from the same spot as a few other Left Hand lights. The lot is fed from fuse 4P (10 amp) in the central junction box. Would impact lights front and rear if that fuse was blown. Rover calls them side lights and side marker lights. Side light would be also known as city light or daytime running light. If blown, and keeps blowing, perhaps LED is attached in reverse direction (it is a diode).
File Type: pdf
Old Apr 15, 2012 | 09:10 AM
Ajs5691's Avatar
3rd Gear
Thx savannah...I will try that today....I will update
Old Apr 15, 2012 | 10:02 AM
Ajs5691's Avatar
3rd Gear
Hey savannah....that was it...spilled everything that was in my glove compartment....but the problem is fixed....thank you so much
Old Apr 15, 2012 | 11:37 AM
A good wiring diagram is a thing of beauty. BTW, people may not think about it, but LEDs last a whole lot longer. In my county, it is $85 ticket for a bulb out, even the tag light. Sign of economic times.
Old Apr 16, 2012 | 10:59 AM
Rovin4life's Avatar
led lights blow the crap out of the bcm. seen it a few times
Old Apr 17, 2012 | 09:22 PM
Danny Lee 97 Disco's Avatar
What is the BCM?
MoNtErover
Sep 24, 2008 08:08 AM
jobob307
Jul 2, 2008 07:26 PM
95raingerowver
Feb 19, 2008 07:28 AM
dustin309685
Nov 18, 2006 07:45 PM
russ00001
Aug 6, 2006 03:54 PM
