Sponsored by: CARiD
Emissions System Critical Failure
Old Aug 3, 2010 | 04:05 PM
RealRitzcracker's Avatar
Default Emissions System Critical Failure
The guy that read my codes said they all had to do with the emissions system.
He said O2 Sensor Bank 2
Then he said the following codes
0430
1415
1412
Old Aug 3, 2010 | 05:25 PM
We need to know the year and model.
Yes the O2's are emissions control.
Depending on the model depends on what could be wrong.
Old Aug 3, 2010 | 09:23 PM
2004 Discovery II
Thanks
Old Aug 5, 2010 | 12:21 AM
Rovin4life's Avatar
1412,1415 are secondary air. maybe a hose loose or a bad valve. 0430 is the passenger side catalytic converter is failed.
fix the secondary air codes first and clear the codes and do the drive cycle and see if it passes inspection. if it still fails with the 430 in it then you need some new catalytic converters be mindful you have 80k and 8 year warrantee on the converters. if that is the case then have the dealer change them and diagnose the vehicle. the converter will be under warrantee.
Wayne
Oct 2, 2020 12:10 PM
desidude
LR2
May 31, 2014 08:03 AM
jmason
Mar 15, 2013 12:10 PM
Travelor
Jun 26, 2011 02:35 PM
Israel Virella
Sep 29, 2010 10:02 AM
