Sponsored by: CARiD
High rev on startup now that it is cold
Old Nov 23, 2016 | 11:20 PM
Rover_Hokie's Avatar
Default High rev on startup now that it is cold
First 40ish degree day and D2 stays at high throttle when started, very high. I am used to a little but this is like revving it. Concerned when it gets really cold that thick oil could damage the engine. Any idea what the problem may be?
Old Nov 24, 2016 | 01:46 AM
JUKE179r's Avatar
It might be your IACV. Try removing and cleaning out your idle air control valve with throttle body cleaner
Old Nov 24, 2016 | 02:01 AM
Racer X's Avatar
What's the RPM you're seeing?
Old Nov 25, 2016 | 10:51 AM
2100 RPM for 5 min then steps down 500 every 30-40 sec. to settle around 800-900 after about 10 min. BTW yesterday at 60 degrees this happened.
Old Nov 26, 2016 | 02:53 PM
abran's Avatar
2nd the IACV.
also look for leaks after the MAF.
while running spray brake cleaner all all hoses, gaskets, and connections. If you get a change in the motor you will have found the leak.
try under the upper intake, could be injectors as well.
no codes?
VikingDiesel
Apr 6, 2018 11:11 AM
robersonb
Jul 14, 2013 07:18 PM
Yorkie
Apr 19, 2012 09:21 AM
Spencerfitch
May 9, 2010 04:44 PM
rravenn13
Jul 19, 2007 04:40 PM
