high speed vibrations!!! need Help
If a Discovery 2, don't drive, and inspect for front prop drive shaft. If shaft does not have multiple grease fittings, and has not been greased frequently (best every oil change), then it can split. When it flies apart, it can poke a big hole in transmission case. Who needs a $7000 transmission job from the dealer? There is a write up in the tech section on rebuilding it DIY, https://landroverforums.com/forum/sh...ad.php?t=29302, or you can buy new shaft and have installed by driveline shop or mehanic or DIY. You can remove shaft IF you have a CDL that you can lock (either installed or with a spud on the transfer case that was never attached to a lever), and just drive on rear wheel drive.
