Sponsored by: CARiD
high speed vibrations!!! need Help
Old May 14, 2012 | 10:23 PM
Urbanrider11's Avatar
Default high speed vibrations!!! need Help
I noticed my 99 Disco I is having vibrations, they are noticeable at low speeds but increase at high speeds. When I release the throttle the vibrations stop and it coasts smoothly. Any advice on what might be causing this?
Old May 15, 2012 | 04:21 AM
If a Discovery 2, don't drive, and inspect for front prop drive shaft. If shaft does not have multiple grease fittings, and has not been greased frequently (best every oil change), then it can split. When it flies apart, it can poke a big hole in transmission case. Who needs a $7000 transmission job from the dealer? There is a write up in the tech section on rebuilding it DIY, https://landroverforums.com/forum/sh...ad.php?t=29302, or you can buy new shaft and have installed by driveline shop or mehanic or DIY. You can remove shaft IF you have a CDL that you can lock (either installed or with a spud on the transfer case that was never attached to a lever), and just drive on rear wheel drive.
Old May 15, 2012 | 05:10 PM
socalrovershop's Avatar
check the ujoints on the drive shafts and also make sure the rear coupler on the drive shaft to the rear diff is still in good condition. when they start to tear they cause a vibration. also a cracked flex plate will do the same . good luck
Old May 21, 2012 | 09:44 AM
Thanks I did what you all suggested it was the u joints they were worn out..
Old May 21, 2012 | 11:27 AM
You can go buy a lottery ticket because you are a lucky guy!
Old May 21, 2012 | 01:11 PM
So, in the future, start lubing them at least twice a year.
Old May 21, 2012 | 02:47 PM
antichrist's Avatar
Or lube them (at least) on the correct schedule which is every 5,000 miles or 3 months, for "normal" service.
sickws6
Jul 27, 2015 09:04 AM
dipdgarage
Apr 15, 2014 09:17 AM
fj60disco
Mar 8, 2011 06:19 AM
soupdogg
Sep 25, 2007 12:49 PM
Bene
Apr 27, 2005 12:56 AM
