Sponsored by: CARiD
How to clean oil gunk from underside?
Old Feb 24, 2011 | 05:39 AM
Default How to clean oil gunk from underside?
Have 97 Disco 1, 170K, previous owner operated on beach sand with significant fluid leaks. Now I have oil & dirt scum from radiator cross member to behind cats. It is 1/8th to 1/4 inch thick in most places. Used spray car wash with engine cleaner, did not get much, left wave pattern in the sludge on some chassis parts. Used Purple K and brush, very slow going. Used tiny "steam shark" steamer, does work in small areas. Found leak on front seal, vehicle seems to have thicker coating of gunk on driver's side, may have steering box leak. Coil springs normal on right side, coated 1/4 inch on left side. Note: I had already found the PO had seldom cleared the oil separator for the valve cover, which may have contributed to the seal leak. With four hours in it so far, I have made it from the radiator to the front of the oil sump.
Any ideas or precautions would be appreciated.
Old Feb 24, 2011 | 12:13 PM
Have it steamed cleaned while on a rack.
Old Feb 24, 2011 | 06:19 PM
Just take your time.
You dont have to remove it all at once either.
Old Feb 25, 2011 | 10:23 PM
CT fan's Avatar
you could try spraying some cheap carb cleaner of the wal-mart brand...
coors
May 11, 2011 08:14 PM
ChanchoVerde
Mar 28, 2010 02:17 PM
LR03NJ
Mar 5, 2010 10:51 PM
avking
Feb 18, 2009 05:10 PM
CPDieker
Sep 19, 2007 11:18 AM
