Sponsored by: CARiD
How I fixed my Land Rover tick (slipped sleeve)
Old May 4, 2012 | 08:20 AM
  #41
PJCSr's Avatar
I kind of thought that I could do pull it off in a weekend.
I am still diagnosing to see if it truly is a sleeve that has slipped. I had the heads rebuilt by a shop that I have never used and I think that they might have missed a bad rocker. That is what it sounds like to me. Also, I had talked to a Master Tech here in Charlotte and he is convinced that it is valvetrain and not a slipped sleeve. He listened to it with a stethoscope and it does sound like it is under the valve covers. We are going to open it up next week and see. He also mentioned that I have a Bosch block and that the sleeves in the Bosch block don't slip. I am still doing research on that.
Anyways, I am going to eliminate the valvetrain as a possibility before I consider the sleeves.
Thanks again. I will update when I know.
PJC
Old May 5, 2012 | 09:56 PM
  #42
rudawski's Avatar
I have a bosch block, and so does everyone else with a 4.6L in my assumptions. The sleeves will slip and do slip unless it is top-hatted. Honestly, I don't blame you for wanting it to be in the top end. I'm willing to bet it is not. Take a look and let us know what if anything you find.
Old May 10, 2012 | 11:28 AM
  #43
grips03's Avatar
my 04 disco makes tick tick tick sound, do you have part number for oil pressure test kit that fits the 04 disco? Also how is the test done performed.
Old May 14, 2012 | 12:38 PM
  #44
ltbrkm3's Avatar
4th Gear
Default Ok, no tick at all for me.....
..just a constant coolant loss with no leaks anywhere. The engine has been completely resealed. I was ASSuming that the only other possibility was a slipped sleeve. I can smell coolant and have used leakstop as a "what the hell I have nothing to lose at this point" fix and the coolant consumption stops...for a little while, then comes back. Strange that it does not tick though. Any other ideas guys? Also, it runs rough, after sitting, for the first approximately two minutes and then is smooth, the "service engine soon" light comes on but goes back out after several starts the same day. If it sits for a couple of days the process starts all over again. The spark plugs I just changed(in an effort to make sure they were ok) looked like they were dirty-not clean like a cylinder getting coolant in it.....gotta love these engines....
Scott
Old May 15, 2012 | 07:53 PM
  #45
rudawski's Avatar
ltb,
If you are using coolant and you suspect a sleeve issue, this fix will do nothing. This is meant to stop liners from moving, you would have either a head gasket/head issue or a cracked block behind the sleeve. In this situation, it would continue to leak and your problem would continue to **** you off. I would pull the heads, check the gaskets and pressure test the block. There are you tube vids for pressure testing the block on these engines.
Good luck
Old Jun 2, 2012 | 03:53 PM
  #46
Razorback Disco's Avatar
8th Gear
Wink
Originally Posted by rudawski
toad,
Is that 04 Disco ticking or has it not "matured" yet? Mine started at 118k. I think that is the magic number. I have read several threads that start with "I love my 03/04 Disco, but at 120k it started to tick" I don't mean to jinx things for ya if its not!
My 2004 started ticking around 80,000. It only bothers me when I'm in a drive-through, sitting at a light, or when the engine is running. I have found that letting it sit in the driveway for long periods of time will make the tick go away (provided the engine isn't running).
Old Jun 3, 2012 | 07:16 AM
  #47
rudawski's Avatar
Good point
Old Jun 7, 2012 | 09:24 PM
  #48
Ai Humlae's Avatar
3rd Gear
I'm pretty sure mine are slipping. May I please have the shopping list for the pieces I'll need, including gaskets, oil, which set screws, quantity...etc. Thank you in adavance.
Old Jun 8, 2012 | 01:08 PM
  #49
autopartsmike's Avatar
Hi, I am in a similar situation and was wondering if you you had any other photos?
Thanks autopartsmike
Old Jun 8, 2012 | 01:48 PM
  #50
roverguy67's Avatar
Man That was THE BEST post ive read in a long time!!!! great advice and funny as hell....
