Sponsored by: CARiD
Intake Manifold Gasket
Old Jun 25, 2010 | 10:20 PM
jasonabarrett's Avatar
Default Intake Manifold Gasket
I am going to be replacing my intake manifold gasket soon, I have been pricing and looking online for them. Do I have to replace the valley end seal gasket or just the valley gasket? I am not really sure what the valley end seal gaskets even are. Any help would be appreciated. THANKS!
Old Jun 26, 2010 | 02:03 AM
So why are you doing gasket replacement and be more specific are you replacing the valley pan, if so, yes the ends also or the intake gasket between the top and bottom manifolds, which you should probably do as well along with the valve covers and plug wires.
Old Jun 26, 2010 | 08:38 AM
Default intake gasket
Mike
I will be replacing the gasket because it is leaking up front just above the water pump where the manifold attaches to the engine. I just assumed that valley pan gasket was what needed to be changed. Am I wrong?
Old Jun 26, 2010 | 09:08 AM
Rovin4life's Avatar
if it is coolant leaking then add dye to make sure its not the head gaskets.
Shryan
Apr 1, 2013 08:53 PM
Scott Weiland
Dec 30, 2012 09:58 AM
rick.miles
Aug 9, 2012 06:56 AM
maxellfullmoon
Jul 26, 2010 09:09 PM
jbriggs
Jul 14, 2006 01:07 AM
