Sponsored by: CARiD
L320 Electrical issues, any help appriciated
Old Jul 1, 2025 | 02:12 PM
Mr.Wilson's Avatar
Default L320 Electrical issues, any help appriciated
Hello guys, so I have this customer with an 2008 L320 RR Sport 3.6TDV8 200kw and his issue was that while driving the front right suspension would go haywire while driving which is why he had the car towed in, from what i could gather from him the front right wheel would start to change height while driving, but I could not get the issue to repeat, i had a scanner with me to ensure i can see the issues as they arise. Before going on the test drive, i had a general overlook at the contition of the wires on the front right height sensor, i took off the connector, cleaned it and i took the shielding off all algong until it enters the front bumper plastics and tried to pull on the wires to see if they would snap and there would be my issue, but to no awail, i also checked under the dash where the air suspension control module is and moved those wires around while a collague was looking at real time data to see if we would lose the signal, but also no luck, after all these tries i had to get home so with customers permission i took the car home along some bumpy roads to see if i could recreate the issue, but no luck, after getting home i scanned it again and i will pist the dtcs that came up, i am thinking that this may be a ground issue, as while taking a short trip before the long one home, the middle screen on the instrument cluster also went out, but after restarting the car the issue was resolved(also the customer said that all the issues would be fixed after turning the car on and off, i have no idea if he waited) but also maybe these things are on the same network and im thinking horribly wrong. Any help would be appriciated as i would perfer not to have to tear the whole thing apart, thank you in advance.
These are the only ones that stayed after clearing
Conch
LR4
Apr 23, 2025 04:54 PM
DesertDiscoHD
Range Rover L322 (3rd Gen)
Aug 7, 2023 09:14 AM
dom2482
May 21, 2023 05:26 PM
PoppyW
Jun 26, 2021 03:12 PM
Matthew Lord
Mar 13, 2020 09:22 AM
