Sponsored by: CARiD
no power getting to rl18 - ac compressor relay
Old Apr 4, 2013 | 11:23 AM
cbmcpa's Avatar
5th Gear
Default no power getting to rl18 - ac compressor relay
Hi all,
hit a bump in the road the other day and my ac stopped working - compressor is good, freon full - no power getting to compressor - no power @ ac compressor relay rl-18
what do i do next? thanks in advance for your help. .
Old Apr 4, 2013 | 02:47 PM
gprtech's Avatar
What's the vehicle?
Old Apr 5, 2013 | 07:00 AM
cbmcpa's Avatar
5th Gear
Originally Posted by gprtech
What's the vehicle?
Oops - im a newbee
2000 RR 4.6
Old Apr 5, 2013 | 07:41 AM
Fuse 37 under hood, or Relay 19 (feeds fuse 37), or the dual pressure switch, which is in the ground side connected to the relay coil, and with the switch ground supplied by the HEVAC control unit. Not sure how you measured for power, but a volt meter with one lead on negative battery or frame ground can be touched to both sides of the fuse to verify volts there (eliminates relay 19). The dual pressure switch controls more than one thing. If refrigerant very low or compressor head pressure too high switch shuts things off to prevent damage.
Old Apr 6, 2013 | 06:13 AM
cbmcpa's Avatar
5th Gear
Thanks - will check all and back to you - plenty of freon - thus not shutting off for that reason
Old Apr 6, 2013 | 04:23 PM
Rovin4life's Avatar
If I am not mistaken there is a connector on the driverside and passenger sides that are white underneath the dashboard in the kickpanel that controls that function. Lots of time they get corroded up.
Old Apr 6, 2013 | 06:21 PM
Yep, that C0067 is in a bad spot....
Attached Thumbnails no power getting to rl18 - ac compressor relay-rr-c0067.jpg
Old Apr 7, 2013 | 06:16 AM
cbmcpa's Avatar
5th Gear
That soinds wsy more like it - i dare to ask how to get to it
Old Apr 7, 2013 | 06:21 AM
cbmcpa's Avatar
5th Gear
And would that show a particular code?
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
poster112
Mar 28, 2014 06:05 AM
coldstart
Mar 9, 2014 07:08 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
