I just went to Advance and had them hook up their OBDII scanner to my 2000 Disco II, i got back a code P0455 , an emission control system leak . I was wondering if any of you guys had a good starting point for me, to figure out what is wrong? Thanks
This code is actually for "Gross Leaks", could be a really bad gas cap to a vapor leak from one of many vapor lines from the canister to the fuel tank.
Yeah,check your gas cap, for some reason after time the cap fitting in the filler neck will become to tight, causing the cap to "click" before it is fully seated/sealed. a new cap will remedy this. check the fitting does it close freely or with alot of resistance?
