Sponsored by: CARiD
OBD code P0455
Old Jan 21, 2008 | 12:56 PM
tlester72's Avatar
Default OBD code P0455
I just went to Advance and had them hook up their OBDII scanner to my 2000 Disco II, i got back a code P0455 , an emission control system leak . I was wondering if any of you guys had a good starting point for me, to figure out what is wrong? Thanks
Old Jan 21, 2008 | 02:27 PM
Default RE: OBD code P0455
This code is actually for "Gross Leaks", could be a really bad gas cap to a vapor leak from one of many vapor lines from the canister to the fuel tank.
Old Jan 21, 2008 | 04:27 PM
kjverock's Avatar
7th Gear
I'd bet my house its a Gas cap failure..
They can be had for about $30 @ the dealer.
Install it yourself and save about 3 hours worth of diag testing. [:'(]
Old Jan 21, 2008 | 08:17 PM
lrobin3w's Avatar
Yeah,check your gas cap, for some reason after time the cap fitting in the filler neck will become to tight, causing the cap to "click" before it is fully seated/sealed. a new cap will remedy this. check the fitting does it close freely or with alot of resistance?
CaptainCulp
Aug 6, 2014 08:05 PM
tastandish
Jun 15, 2012 03:30 PM
dieselburban
Jan 25, 2011 10:49 PM
Disco Fuego
Apr 11, 2009 10:31 AM
mhowarth
Jun 22, 2007 01:33 AM
