Sponsored by: CARiD
Service Engine Soon Warning?
Old Dec 15, 2011 | 01:40 PM
  #21
couzteau's Avatar
UlttraGauge is currently out of stock. Will get ASAP:
UltraGauge, OBD II Scan Tool & Information Center
Old Dec 19, 2011 | 01:57 PM
  #22
couzteau's Avatar
The problem was resolved by replacing both sensors (Engine ECT + radiator out) and and the thermostat.
Interpreting the error code was somewhat confusing: "P1118 Radiator outlet temperature thermister high, Thermostat reading above 140 °C (284 °F)"
Since the warning does indicate a problem with thermostat leakage I would expect the engine being too cool rather than too hot, but if the radiator out is above 140C then the engine must be really hot which would not relate to thermostat leakage, but may be to a thermostat that doesn't open sufficiently.
That said, the issue seems to be fixed now and I don't think the engine was overheating, because the was no warning on that. Neither temp gauge, nor another warning light.
Old Dec 19, 2011 | 02:16 PM
  #23
Thanks for the followup, you probably saved you engine...
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
AMANDAMC
Sep 23, 2007 11:14 AM
hippo2002
Freelander
Dec 19, 2005 01:31 AM
Woody Reems
Nov 29, 2005 06:08 PM
rinmud
Oct 1, 2005 04:32 PM
