Sponsored by: CARiD
thick white smoke coming from the tail pipe
Old Jan 2, 2010 | 12:12 AM
big will's Avatar
6th Gear
Default thick white smoke coming from the tail pipe
so it seems everytime i take my car in it comes back with a new problem. The car was fine unti l a day ago i'm sitting at a light and the smoke started coming heavy and still is. I'm going to take it back in but don't want to be told it's something it's not and be over charged. any suggestions? 02 disco II
Old Jan 2, 2010 | 09:10 AM
Baylink's Avatar
Try and catch some of it on a piece of glass, and see if it condenses into water droplets. If so, head gasket. Sorry. :-}
Old Jan 2, 2010 | 01:53 PM
tedly797's Avatar
Did the car ever overheat, loose coolant? If so, you can fix the leak but the damage may have already been done internally. Usually head gaskets or dropped liner will give you that white smoke ( does it smell sweet like coolant?).
unfortunalty heat is these motors worst enemy! Good luck
Old Jan 2, 2010 | 02:03 PM
big will's Avatar
6th Gear
there was a coolant leak and i start school monday so to save $$$$ i figured i would be ok to just make sure there was coolant in it. the leak was in the top of the radiator right next to the screw that i can't figure why it's there. So if the head gasket is the issue what should i expect for a quote? Labor? parts?
Old Jan 14, 2010 | 11:26 PM
Mrmerlin's Avatar
1600.00 for new head gaskets and machine work
JustinIISEries
Dec 25, 2014 07:21 PM
oysterhead
Jan 25, 2011 07:12 PM
Hatterasvillager
Oct 19, 2010 12:48 PM
Lil-Kim-got-My_sandwich
Aug 8, 2010 05:08 PM
jwmstang
Apr 12, 2007 10:31 PM
