Sponsored by: CARiD
Urgent Brake help!
Old May 1, 2007 | 02:24 AM
WINDman's Avatar
4wd High
Default Urgent Brake help!
Hi I am new here and was hoping someone could help me out? I recently had to replace the Master Brake cylinder, all slave cylinders and the brake switch on my 79' Series III SWB because it was leaking. After I fitted all the parts, and bleed the brakes, I tried to apply the brakes and the pedal would loose pressure and go to the floor, only after a few pumps of the brake pedal will it return to normal operation. After driving a while the same thing happens when I apply the brakes. I've tried different bleeding of the brakes and my mechanic even tried to pump out the system but the same thing happens, any ideas? Thanks for any advice.
Old May 1, 2007 | 11:07 AM
Default RE: Urgent Brake help!
Did you prime the master cylinder with new fluid before you installed it?
Mike
Old May 1, 2007 | 12:12 PM
WINDman's Avatar
4wd High
Hi Disco Mike, yes I did, I do however notice that there a slight seepage of brake fluid from the new brake switch, could it be the brake pressure distribution valve? I can't see anything else I could have done wrong?
Old May 1, 2007 | 01:28 PM
That seepage could allow air into the brake lines.
Mike
Old May 1, 2007 | 04:29 PM
WINDman's Avatar
4wd High
ok cheers, I guess I'll try replacing the valve.
Old May 1, 2007 | 06:39 PM
ArizonaDiscovery's Avatar
I dont have any exp. with the 79 III but I had a similar problem on my Porsche. The switch would be the number one guess for me. Any seepage in the brake system is unacceptable, point blank, period.Its practically the one thing on therover that shouldnt leak.
Old May 2, 2007 | 02:41 AM
WINDman's Avatar
4wd High
thing is the switch is brand new, and I had to order everything with great difficulty because I am overseas. My truck's been off the road since January.
Old May 2, 2007 | 12:06 PM
Adz's Avatar
Adz
Just about anywhere where brake fluid will get out, air will get in - as has been said above, fix all apparent leaks, rebleed the system on all four corners and try it again.
One thing the series brakes are prone to and if it does this while stationary then this will not apply to your situation, if the drums aren't properly round (you'll need to check them with a micrometer or caliper to be sure, even if they look round) the pistons get pushed back into the cylinder as the drum rotates, forcing fluid back into the reservoir. Depending on how ou of true the drum is depends on how far the piston gets pushed back in - but it has a similar feel to air in the lines and can mean the pedal will drop almost to the floor on the first press of the pedal - pumping the brakes brings the pistons back out and normal braking is resumed.
Hope that helps,
Old May 2, 2007 | 12:08 PM
WINDman's Avatar
4wd High
I was told I can remove the shuttle valve entire, and fit two unions to join the piping, minus the valve. That way the two sections are still seperate.
anyone here can confirm this? I have 2 inlet pipes and 3 outlets from the shuttle valve, has anyone done this here before? thanks
Hyakku
Sep 13, 2010 09:44 AM
Torancis_LR
Jul 10, 2009 11:27 PM
Takeyoubystorm
Nov 23, 2007 10:54 PM
kinsella
Apr 21, 2007 10:21 AM
irishrover90
Dec 28, 2006 02:04 AM
