Sponsored by: CARiD
wont start
Old Nov 7, 2012 | 07:36 AM
Discogirldisco's Avatar
4th Gear
Default wont start
i have a 2001 Td5 disco which has just had the fuel pump replaced and the pressure regulator at the injectors replaced but it still wont start. Once it is going it travels well and will start again straight away but not after more than 30 mins turned off....
Old Nov 7, 2012 | 08:16 AM
4th Gear
just wondering too, which 3SE model is the best one? it might be time to say goodbye to TD5.......
Old Nov 7, 2012 | 09:56 AM
You may not get many replies from this site since virtually none of us have diesels in the States,
Old Nov 7, 2012 | 08:55 PM
Your fuel system has a leak and you are getting air in the fuel system, cranking the engine over for a long time will eventually purge the air out of the system.
Unlike a petrol engine a diesel cannot have any air in the fuel system as the fuel is injected directly into the cylinders under 30,000psi.
If air gets into the injector pump then you really are in trouble because then you need to bleed the injector pump of air, and then the fuel lines.
So you need to find your fuel leak, either fuel is leaking backwards out of the system or through the injectors into the cylinders.
Does it smoke really bad when you start it after sitting?
Does it fire and run for a second or 2 after it has sat?
Does it spit and sputter for a min after sitting?
Or does it just crank and crank and crank until it finally starts?
Old Nov 8, 2012 | 07:18 AM
4th Gear
Hi Mike,
thank you very much for your help it does smoke a lot when it starts. It just cranks but wont fire. maybe when the fuel pump & pressure regulator were changed something happened causing a fuel leak. It will start immediately if it has just been running but if left for more than 30 mins it is unwilling and has deteriorated to the point where it wont start at all.... whereas before with the accelerator down it would start. Once it is going it is faultless!! Someone mentioned the plug from the fuel injector wires to the computer might have oil on it too causing a computer malfunction? Will look into theposibility of a fuel leak straight away. thanks again
Old Nov 8, 2012 | 07:21 AM
4th Gear
oopss that was meant for spike and thank you mike I did not know most LR D's were petrol in the states.
Old Nov 8, 2012 | 07:54 AM
Yes, diesels are few and far between in the States, and with our election just over, gas prices will rise again. Diesel is already at $4 a gallon near me, and petrol at $2.99 (last week).
Old Nov 8, 2012 | 06:42 PM
With it smoking alot when you start it your fuel injectors are probably leaking fuel into the cylinders, it smokes because the extra fuel is being burned off.
It could also be a wiring issue, start there.
We have a truck at work that was hard to start after sitting all night, it was not getting any fuel because of a wiring issue, it would eventually start and smoke really bad.
Fixed wiring issue, no problems since.
Old Nov 8, 2012 | 07:05 PM
Must be nice, diesel has not been below $4.09 or petrol below $3.50 (regular) for over a month here.
Old Nov 8, 2012 | 08:13 PM
The oil companies were waiting for the election to be over, so they could raise prices and start funding more politicians. I don't know if Demoncrats are pricer than Republicants; but I'm proud that we have the finest politicians money can buy!
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
