08 LR2 cap on wheel lug nut is spinning
Old Jul 6, 2021 | 03:27 PM
LR2driver's Avatar
Default 08 LR2 cap on wheel lug nut is spinning
Searching the forums and YouTube, this appears to be a common problem where the ornamental cap on the lug nut is no longer snug and just spins when you turn it with a 21mm socket (for my 19" wheels). This is a bad situation if you need to change a flat tire on the roadside because a routine wheel change will become a "project" to get that lug nut off.
I'll be tackling this over the weekend and will post back. It's always something, but at least it's not the transmission
Old Jul 6, 2021 | 09:54 PM
merlinj79's Avatar
I bought a bag of new ones, and replace them as needed when I rotate tires.
It's hard to get tire shops to treat them gently. Bad design.
Old Jul 10, 2021 | 07:33 PM
LR2driver's Avatar
Glad to hear I'm not the only one with this issue. And I feel lucky that after all this time only one of these nuts failed.
I have four new/spare lug nuts that I saved after I bought the car when I replaced them with McGard wheel locks. So now, 13 years later, I'm glad to have saved them.
I thought it would be a struggle to pull the cap off, especially after watching a Youtube video where they had to punch a hole in the center and peel it off. So I taped around the lug to avoid scratching the wheel during the anticipated combat. I got some pliers on it. After a little wiggling and cursing, it came right off. Much easier than I expected!
The head size of the wheel nut (with cap) is 21mm. The naked nut under the cap will come off with either a 21mm or 20mm socket.
I replaced the nut with a new one and torqued to 98 ft-lbs. For good measure, I torqued all the nuts on all the wheels to ensure none of them also had a loose cap. All good.
I hope the next repair is so simple and easy.
Old Jul 10, 2021 | 11:36 PM
merlinj79's Avatar
Rotated my tires yesterday, a bunch of them were too warped for the 21mm socket to fit right. I tried SAE sockets, they didn't seem to fit any better
Fortunately the lug wrench that comes with the car fit better.
I used the lug wrench to loosen and tighten them, and a 22mm socket to spin them on and off with an electric drive.
I'm going to try to find a solid lug nut that will look OK and not change it's socket size when Discount Tire uses an impact wrench.
Old Jul 11, 2021 | 12:08 AM
LR2driver's Avatar
You convinced me to buy a 22mm socket to have on-hand "just in case".
Old Jul 13, 2021 | 11:57 AM
p_gill's Avatar
Here are the specs if you need a new lug bolt or several
M14 x 1.5
60 Degree Captive washer
25 mm depth (minimum 23 mm threaded)
21 mm drive socket compatible
Freel2 thread about this issue https://www.freel2.com/forum/topic36763-15.html
Thanks
Paul
Old Jul 13, 2021 | 12:16 PM
merlinj79's Avatar
Thanks, I'll report back what I find.
Old Jul 13, 2021 | 12:22 PM
flybd5's Avatar
Don't buy multiple socket for onesy-twosy applications. Buy a universal socket.
 Or better yet, a set of two. Or better yet, a set of two.
Old Jul 16, 2021 | 07:17 AM
guy's Avatar
guy
yes, these issues arise where the wrong sized socket is used and an over zealous mechanic uses an over powered impact wrench.
I haven’t been so particular with the LR but with the Jag I insist on hand tools and right sized sockets only.
EricTyrrell
May 10, 2022 01:42 PM
jeff spahn
Apr 19, 2012 04:22 PM
acsink
May 31, 2011 08:38 AM
SFlynn2nd
Jul 9, 2010 08:20 PM
kjordan
Feb 20, 2010 04:38 PM
