Coolant light on in cold weather
Old Jan 4, 2021 | 08:32 PM
flybd5's Avatar
Originally Posted by Jpg
Got the printout from Autozone. I thought all 2013 LR2s were turbo, and it's definitely not diesel. Got any friends around Baltimore you recommend? I can take it to my regular place (they're pretty good and will tell me if they can't handle it) or the dealer if absolutely necessary.
​​​​​​I have a 2008 so I am not familiar with your model. I also don't know any shops in Baltimore. Call your regular shop and ask if they can handle it, otherwise you may have to go to the dealer
Old Jan 10, 2021 | 08:04 AM
guy's Avatar
guy
fwiw, despite the assumptions; my dealer completes work efficiently as they know the vehicle. And price fairly.
The one time I had a simple job of the brakes completed not at the dealer, I was back at the dealer within 6 months to get the brakes done again... The Independent’s charge was equal to the dealer’s. The quality of the parts was severely lacking...
If the turbo is cracked (a common issue on the Ford ecoboost engine). it can be welded... but there would be no warranty on the fix.
Many don’t realize that all dealers provide a 1 year warranty on parts and service provided at the dealer...
Old Jan 10, 2021 | 08:06 AM
flybd5's Avatar
Mileage varies. In Massachusetts dealers overprice *everything* and I have no problem finding a competent independent mechanic.
Old Jan 10, 2021 | 08:09 AM
guy's Avatar
guy
There WAS a jag dealer in Waltham I would routinely visit as they were tremendous... maybe that’s why they are out of business...
Old Jan 10, 2021 | 08:16 AM
flybd5's Avatar
That may be because my outstanding independent LR mechanic is in Waltham.
guy's Avatar
guy
but back to the subject line... I too have the 2013 model. I suspect there is sufficient expansion/contraction during the cold winter months as it is only in the winter that I need to top up the coolant. I always fill to slightly above the maximum mark and let the level come to an equilibrium on its own.
While on the topic of coolant, have you ever done a coolant flush on your engine? After this many years it is really important as the fluid becomes corrosive over a long time.
Old Jan 10, 2021 | 08:18 AM
flybd5's Avatar
I do coolant flush every time I have Jiffy Lube change the oil and filter... every 6,000 miles.
Old Jan 10, 2021 | 08:23 AM
guy's Avatar
guy
Wow! I’m proactive but not that proactive. What does that cost you in Mass?
Old Jan 10, 2021 | 08:26 AM
flybd5's Avatar
I can't remember, but it's a good deal with the veteran's discount. I also do the engine oil flush but I do that with Liqui-Moly's product. I dump it in there for 10 minutes before I drive into the Jiffy Lube stall.
Old Jan 13, 2021 | 09:50 AM
akmega's Avatar
Hi everyone! I have a 2013 LR2 which I’ve owned for 3 years. Each winter the coolant warning light comes on. It goes on and off while I’m driving. I park in my garage overnight and there is no evidence of a leak on the floor. Temp gage reads normal.
Any ideas, and should I be concerned about this?
Thanks!
I had the same issue last year so replaced the expansion tank and the sign went away and last Month coolant was getting low again and I found out it was the engine coolant Reservoir hose which I replaced and no more coolant leak
grapple
LR4
Feb 15, 2020 01:24 AM
MichaelDisc02
Feb 26, 2015 04:56 PM
dragan
Jan 30, 2014 09:20 PM
JAC
Oct 2, 2009 09:41 AM
MidasHands
Jan 5, 2008 01:39 PM
