06 lr3 no start/no crank after battery removal
Old May 19, 2013 | 12:24 PM
nino's Avatar
5th Gear
Default 06 lr3 no start/no crank after battery removal
hi again, well i was going to install an aftermarket amp in a 2006 lr3. so i removed the battery then unplugged the 3 front connectors on the fuse box behind the glove and pulled it down slightly, i did not disconnect the rear plugs. i finally did not run any amp wire thru the firewall.
i put the fuse box back on, reconnected the three front plugs, then put the battery back in and reconected.
well now the lr3 will not start. not even crank. i can hear a relay click in the glove box area but it will not start. it will not even let me take it out of park. the red light in the cluster in on a steady blink. i tried a "hard reset" from what i read on here with no luck.
can someone please help me?? any and all help will be greatly appreciated.
Old May 19, 2013 | 01:46 PM
roverguy7's Avatar
You need to recheck those connectors, make sure the front ones are fully seated and latched properly. Past that, I would check to make sure the plugs in the rear of the CJB, fuse box, did not pull out.
If all that is good, and I suggest unplugging and reconnecting those front connectors, then just double check everything you did, battery cables, any connectors around there.
Old Feb 13, 2018 | 11:51 PM
Rey Carpio Castro's Avatar
Have same problem, Is there any way to check those rear conectors from the other side? It's imposible to access them with big hands.
Anyway how did you fix it?
LandoMN
Jul 2, 2024 04:36 PM
airisgood01
Jul 8, 2015 03:31 PM
brian891
Apr 4, 2010 09:11 AM
lipadj46
Nov 17, 2009 11:13 AM
rainluver
Mar 10, 2009 03:57 PM
