2005 LR3 will not start please help!
Old Mar 14, 2018 | 09:19 AM
GMTIIFAN's Avatar
Default 2005 LR3 will not start please help!
I apologize if this has been covered, however I haven't seen my particular issue. when I go to crank vehicle it acts like it's in gear and doesn't turn over radio headlights on as normal. I would move shifter from park to neutral and it would crank normally. I wouldn't have the issue for a while then it would act up again.and it stopped cranking in neutral. I would have to rapidly move the gear shifter back and forth a few times and eventually it would start now that's hit or miss. I thought it was a neutral safety switch related and dealer says that the switch is built in to the shifter assembly and not a seperate part. Well after purchasing the shifter assembly, still will not start. Any suggestions are greatly appreciated and thanks in advance!
Old Mar 14, 2018 | 09:54 AM
abran's Avatar
Have you checked the shift lever on the side of the trans to see if it’s bound or anything looks off?
That’s all I got at the moment.
Any trans related codes? It will store codes without showing an SES light in the TCM.
Old Mar 14, 2018 | 11:13 AM
This would be where I would start looking. It was finicky on my 07
joelh
Oct 16, 2009 09:44 AM
aircraftguy
Nov 21, 2008 01:00 AM
aircraftguy
Nov 15, 2008 08:37 PM
Speed racer
Oct 11, 2008 10:56 PM
jonsimon
Jan 29, 2007 01:55 PM
