Air suspension nightmare
Old May 16, 2020 | 04:24 PM
  #21
DakotaTravler's Avatar
They are idiots. Dont go back to them. There is no reason to upgrade to an AMK compressor.
Old May 16, 2020 | 04:31 PM
  #22
houm_wa's Avatar
This isn't a good old fashioned brake switch situation???
Old May 16, 2020 | 05:00 PM
  #23
Brian Raddick's Avatar
There is new brakes on the rear, Service, and E-brake, and rotors. But there is an issue with the electric gear box. I think there is a stripped gear in it so it won't pull. It tries several times, then gives up.
Old May 16, 2020 | 05:03 PM
  #24
Maybe less than $600. USD ... Up here north of the boarder, that would be around $1000.
Old May 16, 2020 | 07:09 PM
  #25
houm_wa's Avatar
Default That's not what I meant...
...the brake switch is behind the brake pedal, sort of....and can fail due to arching and that causes all kinds of mayhem.
Also brake lights and tail lights are worth a look.
Old May 16, 2020 | 08:33 PM
  #26
loanrangie's Avatar
Looks like a hitachi knock off which should get you by, agree that there are probably other underlying issues. You need to see if you can find someone local that can read the codes.
Old May 16, 2020 | 10:41 PM
  #27
A gear box fault can easily cause other systems like terrain control and air ride fault out. Even a rear diff fault can cause errors.
Old May 17, 2020 | 04:35 PM
  #28
Sorry for the sideways and upside down ones, I rotated 3 times and each time I attached, they were wrong, Hope you can read them,
Old May 17, 2020 | 04:38 PM
  #29
Are those codes read AFTER a total clearing of codes? Casue many look like typical Rover errors, ghost errors that often come up but mean nothing. Or you have a very messed up vehicle, maybe something is not connected at the CJB (central junction box).
Old May 17, 2020 | 05:43 PM
  #30
I don't think they cleared anything. Actually, they recommended scrapping the beast. Can many of those be cleared with a battery disconnect ? Only one that showed on the dash when I bought it was for the Parking brake. I know there is an issue there .
