Alarm sounding for no reason
Old Feb 16, 2026 | 05:21 PM
Canadadian's Avatar
Originally Posted by P-Bod
Thanks everyone for pinpointing my search. I disconnected the hood switch and found a piece of tin foil wedged in the connector as a bypass. I cut and spliced the wires as mentioned above. The switch was definitely dead.
As you probably know the tinfoil was there to disable the faulty connector but I guess that failed over time.
While the hood switch is pointed out as the culprit many times on this and other forums, it is not always the case.
First thing I did was circumvent the switch by using a spade clip to bridge the pins (more secure than tinfoil). Unfortunately that did not solve the problem.
An LR mechanic used his 6 million dollar code reader to establish that it was the passenger door lock actuator. I went and bought a used door and installed it but the problem persisted.
Back to the mechanic who then stated it was the ignition key sensor so I got him to replace it. Still goes off although less frequently and I will be taking the car back to him for further readings. I cannot find anything on my Gap tool that relates to the alarm.
All this to say there can be multiple reasons for this.
Also hoping for help here.
jordamf
Mar 1, 2018 12:44 PM
kevinocall
Jun 2, 2015 01:37 PM
sickvehicle
Aug 4, 2010 12:28 PM
wydell
Oct 28, 2008 12:55 AM
dkeach
Feb 21, 2008 09:30 AM
