AUX Port
Old Aug 29, 2017 | 11:49 AM
EastCoast's Avatar
Default AUX Port
Just wanted to clarify that the aux plug in the rear of the center console is 3.5mm. I tried to plug into it for the first time the other day and the plug would not push in. If it is 3.5 mm then there is something stuck in the plug receptacle itself.
Anyone disassemble the rear console area? If so, tips and instructions to get at the aux receptacle would be greatly appreciated.
Old Aug 29, 2017 | 11:52 AM
Niver39's Avatar
Yes it is 3.5mm
Old Aug 29, 2017 | 11:53 AM
Standard 3.5mm, haven't torn into the back end of the console at all
Old Aug 29, 2017 | 12:40 PM
cmb6s's Avatar
It's possible that something is stuck in it. I know I've read other instances of people having plugs that have broken off stuck in the aux port. Some people also use blanks in order to trick the system into thinking there's something in the port so that they can tie audio into the system at a different point (e.g. behind the glovebox or the passenger side foot panel).
The rear console area isn't hard to disassemble, but I don't think you need to disassemble the entire thing... I thought that part just pulled out separately, but I can't verify right now. The electronics on the backside are not standard by the way... It's not just a 3.5mm jack with two wires coming out. There's a bunch of noise reduction circuitry behind that plastic panel.
Old Aug 29, 2017 | 01:09 PM
abran's Avatar
Yep, Just pry out bezel holding entire assembly in the console. Easy peasy.
Old Aug 29, 2017 | 08:25 PM
EastCoast's Avatar
Figured it out this afternoon... the tabs are on the top lip of the 12v/aux insert so just squeeze down and pull. Managed to get the broken piece out... thanx for help.
XCELLER8
Sep 2, 2014 09:00 PM
TOM R
Mar 27, 2014 11:31 AM
gmcalea
Dec 8, 2008 06:21 PM
The Didge
Apr 3, 2007 11:38 AM
dofbft
Oct 20, 2006 02:09 PM
