Battery Dead - Navigation Screen Stays On
Old Oct 4, 2019 | 03:52 PM
  #21
Shinymyke's Avatar
Originally Posted by js80
I'm not exactly sure but I've tested it a few times now and it eventually does shut off.
I've had my battery tested multiple times (by different shops) and it tests out fine... still not sure what is causing my problems but something is definitely slowly eating away at my battery charge. After leaving it sit for a day in the cold weather, I sometimes get HDC Fault errors and my mileage meter resets (along with the rest of my trip info). I'll be taking it into the Land Rover dealer at some point soon, I think.
I have had this same issue with the HDC fault and that is caused by the wiring harness in the rear left side just behind the wheel. Bad connections so you need to pop it open and clean it then put it back together with dielectric grease. Do it to all 3 connections.
Old Jan 5, 2024 | 12:07 PM
  #22
ArtyParty's Avatar
Hello there and a very happy New Year to you. Apologies, as I realise a little time has gone by, but if you’re still out there, could you confirm the location of the harness you described, please? i.e. Is this external and under he vehicle behind the rear wheel of the car, or is this inside the car in the side locker of the trunk area? I seem to have the same issue and it’s driving me nuts! Many thanks indeed!
Discovery2004
May 31, 2018 08:31 PM
PEPEPEPE
Sep 17, 2012 02:38 PM
lesliesmukler
Nov 7, 2009 05:23 PM
lesliesmukler
Nov 4, 2009 12:15 PM
aircraftguy
Dec 1, 2008 12:56 PM
