Catalytic Converter Part #?
Old Mar 5, 2017 | 08:23 PM
djkronik57's Avatar
Default Catalytic Converter Part #?
Looking for a right/passenger side catalytic converter for my 2008 LR3 HSE. I keep finding two different part numbers, with different prices:
WCD500202: some indication this is for 2005-2006, but other sites show this as the part for 2008? Often appears cheaper.
WCD502470: some sites say LR3; 4.4L; RIGHT; FROM 8A457086 (my vin is 8A46)
Oddly, the driver's side is always WCD502480.
Which is the correct part number, or how would I figure that out? Did they really change the part or can I get the cheapest one I can find of either?
Also, I'm seeing gasket between the converter and the exhaust (#7), but is there one between the exhaust manifold and converter?
Old Mar 23, 2017 | 05:04 PM
djkronik57's Avatar
Ok, so I went ahead and ordered the WCD502470...and it's different than the one I have on their currently and shown in the parts diagram. Instead of the rear O2 sensor being after the converter, it's mid-way through. Everything I look up says it should fit a 2008, but why on earth is the O2 placement different? Should I even try to fit it?
Also, there is a sticker inside on the cat material. I'm assuming that just burns off?
Sticker on the inside of the cat?
Why is the O2 bung midway through the cat?
Old Mar 23, 2017 | 05:32 PM
Coleroad's Avatar
The new one is the way my 07 cat looks like
Old Mar 23, 2017 | 08:11 PM
abran's Avatar
They changed the bung placement in 07'. You are good to go.
Do you mind sharing the cost and source for it?
Old Mar 23, 2017 | 10:35 PM
djkronik57's Avatar
I got it from LRdirect.com from the UK, the cost was a little under $1000 shipped with a the required gaskets and bolts.
Old Mar 23, 2017 | 11:04 PM
cmb6s's Avatar
And by all means, if the two cats that you have differ, tell us which has the easier to access/replace O2 sensor!
Sometimes, those things can be a PITA to get to.
Old Mar 24, 2017 | 08:28 AM
Coleroad's Avatar
As cheap as O2's are I would replace both on the bench, why not.
Old Mar 29, 2017 | 10:22 PM
djkronik57's Avatar
So just for anyone looking at this in the future, WCD502470 fit fine and was the correct part. *whew*
jwmstang
Aug 4, 2022 02:30 PM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
